Q. In the below REGISTER Request, there’s a mistake. Can you figure out on which header it’s present?
REGISTER sip:registrar.example.net SIP/2.0
Via: SIP/2.0/UDP pc33.example.com;branch=z9hG4bK74bf9
Max-Forwards: 70
To: "Alice" <sip:alice@example.com>
Call-ID: 3848276298220188511@pc33.example.com
CSeq: 1 INVITE
Contact: <sip:alice@pc33.example.com>;expires=3600
Content-Length: 0
a) CSeq
b) Call-ID
c) Via
d) To
Check 🔎
Correct answer: Letter a.
CSeq is incorrect in this REGISTER request because the method is INVITE instead of REGISTER.
a)
“CSeq”
→ Correct. The CSeq should match the request method (REGISTER), not INVITE.
b)
“Call-ID”
→ Incorrect. The Call-ID value is valid and unique as expected.
c)
“Via”
→ Incorrect. The Via header format is correct.
d)
“To”
→ Incorrect. The To header format is fine for this REGISTER request.
- “Use the reference coupon below for a significant discount on the course.”
