In radio frequency, the higher the frequency, _______
Q. In radio frequency, the higher the frequency, _______.
a) the higher the capacity.
b) the lower the capacity.
c) the higher distance.
d) the higher the penetration power.
Check πŸ”Ž
:arrow_right: Correct answer: Letter a.
β€œThe higher the frequency, the higher the capacity. Higher frequencies enable greater data throughput by allowing wider bandwidths, but they have shorter range and lower penetration power.”
a) :white_check_mark: β€œthe higher the capacity.”
β†’ Correct. Higher frequencies provide larger bandwidths, resulting in greater capacity and faster data rates.
b) :x: β€œthe lower the capacity.”
β†’ Incorrect. Lower frequencies generally have less available bandwidth, leading to lower capacity.
c) :x: β€œthe higher distance.”
β†’ Incorrect. Higher frequencies suffer from greater path loss, reducing coverage distance.
d) :x: β€œthe higher the penetration power.”
β†’ Incorrect. Higher frequencies have weaker penetration, especially through walls and obstacles.
