Q. In IMS, what allows early media (ringback) before 200 OK?
a) MEGACO Subtract command
b) RTCP
c) SIP 183 Session Progress with SDP
d) SIP PRACK
Check 🔎
Correct answer: Letter c.
In IMS, early media—such as ringback tones or announcements before the call is accepted—is enabled by the SIP 183 Session Progress response with SDP.
- The 183 Session Progress provides the media parameters (via SDP) before the final 200 OK.
- This allows RTP streams to begin flowing even while the session is still being established.
- It’s crucial in VoLTE for user feedback (e.g., network-generated ringback tones).
a)
→ Incorrect. MEGACO handles media gateway control, not SIP early media signaling.
b)
RTCP
→ Incorrect. RTCP provides quality feedback, not media establishment.
c)
→ Correct. 183 with SDP allows the establishment of a media path before call acceptance.
d)
SIP PRACK
→ Incorrect. PRACK is used for reliable provisional responses, but doesn’t itself enable early media.
