IMS Protocols you must know
:satellite_antenna: 𝗜𝗳 𝘆𝗼𝘂 𝘄𝗼𝗿𝗸 𝘄𝗶𝘁𝗵 𝗜𝗠𝗦… 𝘆𝗼𝘂 𝗺𝘂𝘀𝘁 𝗸𝗻𝗼𝘄 𝘁𝗵𝗲𝘀𝗲 𝗽𝗿𝗼𝘁𝗼𝗰𝗼𝗹𝘀.
IMS is not just architecture.
It’s a combination of protocols working together to deliver voice services.
:magnifying_glass_tilted_right: 𝗧𝗵𝗲 𝗰𝗼𝗿𝗲 𝗜𝗠𝗦 𝗽𝗿𝗼𝘁𝗼𝗰𝗼𝗹𝘀
:one: 𝗦𝗜𝗣 (Session Initiation Protocol)
:right_arrow: Used for call setup, modification, and termination
:right_arrow: Core of IMS signaling
:two: 𝗗𝗶𝗮𝗺𝗲𝘁𝗲𝗿
:right_arrow: Used for authentication, authorization, and policy control
:right_arrow: Connects IMS with HSS / PCRF
:three: 𝗥𝗧𝗣 (Real-Time Transport Protocol)
:right_arrow: Carries the actual voice packets
:right_arrow: Works over the user plane
:four: 𝗦𝗗𝗣 (Session Description Protocol)
:right_arrow: Defines media parameters (codec, IP, ports)
:right_arrow: Embedded inside SIP messages
:light_bulb: 𝗞𝗲𝘆 𝗶𝗻𝘀𝗶𝗴𝗵𝘁
VoLTE / IMS is built on:
:backhand_index_pointing_right: SIP (signaling)
:backhand_index_pointing_right: Diameter (control)
:backhand_index_pointing_right: RTP (media)
:backhand_index_pointing_right: SDP (negotiation)
All must work together.
:speech_balloon: 𝗤𝘂𝗲𝘀𝘁𝗶𝗼𝗻
Which protocol do you find most challenging to troubleshoot?
• SIP
• Diameter
• RTP
• SDP
Great post thanks for the knowledge
Stilll please could you help me with the tool you are using to produce such stunning visuals
Need to add H248,Megaco and RTCP as well.
SIP and Diameter are usually the most important protocols during IMS/VoLTE troubleshooting. RTP and SDP also play a huge role in media setup and voice quality.
