If we reduce SSB power by 1dB can it improve RACH like from 3 to 2?
Hello All.
Do you mean ss-PBCH-BlockPower?
And RACH imrpovement 3 to 2 means? (What units, what is 3 and 2?)
Yes this parameter.
RACH will improve if you reduce B1 NR threshold.
Don’t make it -128 dBm, make it -116 dBm.
Do you mean 5G to 4G?
Or inter rat b1 threshold?
Event B1 NR to setup the SCG leg.
Inter rat b1
If during NR VoLTE call is there, and if not disabled NR will it affect NR DCR?
Thanks!
What is good time to trigger? Is it 40ms?
Some MNO use 40msec for N78 and 320msec or even 640msec for N1 to prioritize n78 addition.
When both N1 an dN78 are available
Here it is minus 115.
It is ok, don’t worry. It is band dependent.
Huawei use sometime even -156 dBm
So don’t worry about -115.
Almost all bands in LTE are having minus 115 or minus 108.
B1 threshols
What if we increase beam fail recovery timer?
And reduce detect timer?
I think once a beam fails it is hard to recover no mater of timer.
Ok.
So it means b1 can go either n66, n78 what is there in network.
How can we prioriize for specific NR band to latch first?
As I mentioned before: some MNO use 40msec for N78 and 320msec or even 640msec for N1 to prioritize n78 addition.
So N78 B1 event will be reported first.
