Identifying Fixed Wireless Access devices in the network
Good morning.
Nowadays, the fixed wireless access technology is growing significantly in many different countries. Subscribers recurring to this technology are increasing, attracted by the easiness to connect, and high performance “promise”. However, when operators report their subscribers numbers, they usually do not differentiate between fiber and fixed subscribers. However, there is a big difference between the two, given that FWA will add significant pressure on the mobile network. I was wondering if there is any possible way to differentiate between this two types of subscbribers from an operator, even if it requires network scanning, frequency used by routers, etc.?
Thanks in advance.
Check the IMEIs in the network. IMEIs come from the mobile. FWA models will have specific IMEIs with specific TACs which explain the UE type (phone, modem etc…)
Operator can easily differentiate these two by APN.they usually dont give the same apn to both mobile and FWA subscribers.
