Hunter CE - Site Comparator Module (NOKIA)
Intelligent Configuration Comparison for LTE / 5G Networks
1. Overview
The Hunter Site Comparator is a configuration analysis module designed to compare two network sites - typically one “healthy” (reference) site and one “problematic” site - using consolidated configuration data (CM).
Its objective is simple:
Detect real configuration differences and isolate potential root causes — quickly, objectively, and at scale.
Instead of manually inspecting XML dumps or navigating vendor GUIs, the module processes a consolidated multi-MO dataset and produces structured comparison reports.
It is designed for:
  • RAN Engineers
  • NOC teams
  • Optimization teams
  • Private Network operators
  • Telecom developers building internal automation tools
2. Why This Module Exists
In real network operations, a common situation occurs:
  • Site A is working perfectly.
  • Site B (similar topology) is underperforming.
  • The first question asked:
    “Are the parameters aligned?”
Traditional approaches:
  • Manual XML comparison
  • Vendor OSS side-by-side checks
  • Spreadsheet exports
  • Human inspection
These approaches are slow, error-prone, and non-scalable.
The HUNTER Site Comparator automates this process and delivers:
  • Structured comparison
  • Parameter-level visibility
  • Object alignment
  • UI vs Internal classification
  • Clean investigation workflow
3. Architecture Concept
The module works on top of:
Consolidated_MOS.xlsx
This file is generated by the HUNTER Consolidator and contains:
  • Multiple MOs (sheets)
  • Both UI and Internal parameters
  • Normalized object identifiers
  • Site-level tagging
The comparator:
  1. Filters objects per site
  2. Normalizes distinguished names (DN)
  3. Aligns equivalent logical objects
  4. Compares parameter values
  5. Generates structured Excel output
4. Core Capabilities
4.1 Site-to-Site Comparison
Compare:
  • Reference site (OK)
  • Problem site (BAD)
The module highlights:
  • Identical parameters
  • Different parameters
  • Missing parameters (asymmetry)
  • Object-level inconsistencies
4.2 Intelligent DN Normalization
One of the biggest challenges in configuration comparison is object alignment.
Different sites may have different:
  • MRBTS IDs
  • LNBTS IDs
  • NRBTS IDs
The module masks numeric IDs while preserving logical object structure, allowing:
MRBTS-123411/LNBTS-123411/LNCEL-131
to align with
MRBTS-123499/LNBTS-123499/LNCEL-131
This enables true logical comparison rather than raw string matching.
4.3 UI vs Internal Classification
Each parameter is classified automatically:
  • UI → visible in the user interface
  • Internal → system/internal parameters (suffix _internal)
This allows engineers to:
  • Run a clean “UI-only” analysis first
  • Perform deeper internal audits when necessary
  • Reduce investigation noise
CLI option:
--ui-internal ALL | UI | Internal
4.4 Status Classification
Each compared parameter receives a status:
Status Meaning
OK Same value in both sites
DIFF Different values
MISSING_OK Present in BAD, missing in OK
MISSING_BAD Present in OK, missing in BAD
BOTH_MISSING Empty on both sides
This classification enables structured triage.
5. Output Structure
The generated report contains:
1. Overview
Executive summary:
  • Total comparisons
  • Number of differences
  • Verdict:
    • “Everything aligned”
    • “Differences detected - investigate”
2. By_Sheet
Shows which MOs contain the most divergences.
Useful to quickly identify:
  • Cell-level issues
  • Neighbor-related inconsistencies
  • BTS-level configuration deviations
3. Top_Diffs
Aggregates the most frequent divergent parameters.
Includes:
  • MO
  • Parameter name
  • UI/Internal classification
  • Difference count
4. Diffs_Long (Detailed View)
Full granular comparison:
  • MO (sheet)
  • Logical object (dn_norm)
  • Parameter
  • UI/Internal
  • Value in OK site
  • Value in BAD site
  • Status
This is the main engineering investigation view.
5. Matrix_Wide
Full structured comparison table.
Ideal for:
  • Pivot analysis
  • External reporting
  • Exporting evidence
  • Cross-validation
6. Practical Workflow for Engineers
Recommended investigation sequence:
  1. Run with --ui-internal UI
  2. Check Overview
  3. Go to By_Sheet
  4. Review Top_Diffs
  5. Inspect exact values in Diffs_Long
  6. If needed, rerun with --ui-internal ALL
This reduces noise and accelerates root cause isolation.
7. Typical Use Cases
7.1 Private 4G / 5G Networks
  • Mining
  • Industry 4.0
  • Airports
  • Energy
Where multiple similar sites exist and fast RCA is critical.
7.2 Optimization & Mobility Issues
  • Handover inconsistencies
  • PCI conflicts
  • PRACH/RACH configuration mismatch
  • PLMN/TAC misalignment
  • Admission control thresholds
7.3 Post-Change Validation
After:
  • Software upgrade
  • Parameter mass change
  • Migration
  • Vendor intervention
The module confirms alignment.
7.4 Golden Site Baseline Reference
Can be used in combination with:
  • HUNTER Baseline Module
  • Audit automation
  • Configuration compliance checks
8. For Developers
The module is designed to be:
  • Python-based
  • Pandas-driven
  • Vendor-neutral at logic layer
  • Extensible
Potential enhancements:
  • Severity tagging
  • Parameter criticality mapping
  • Automated root cause suggestions
  • XML-native comparison
  • REST integration
  • Dashboard interface
It is built as a modular block inside the broader HUNTER ecosystem.
9. For Network Operators
You do not need to be a Python developer to use it.
Typical steps:
  1. Generate consolidated MOS
  2. Run comparison command
  3. Open Excel report
  4. Filter differences
  5. Validate findings
No OSS access required during analysis phase.
10. Design Philosophy
The HUNTER Site Comparator follows three principles:
  1. Object alignment before comparison
  2. Signal over noise
  3. Engineering clarity over automation hype
It does not guess root causes.
It exposes facts.
Engineers make decisions based on structured evidence.
11. Strategic Impact
For telecom teams, this module enables:
  • Faster incident response
  • Objective configuration audits
  • Reduced dependency on vendor tools
  • Internal capability development
  • Repeatable engineering workflows
For private network operators, this means:
  • Higher configuration confidence
  • Reduced troubleshooting time
  • Stronger operational maturity
12. Conclusion
The HUNTER Site Comparator transforms a traditional manual task into:
  • Structured
  • Repeatable
  • Scalable
  • Engineer-friendly
  • Data-driven analysis
It is not just a script.
It is a configuration intelligence layer for modern LTE/5G operations.
