There is no codebook config in my log, this is also weird.
Usually we come to see n1 n2.
And if you see eightone it means 16 csi-rs ports that for sure is AAU and not classical antenna.
Ohh I see.
For LTE I can tell how to identify we need to check antenna ports no like p7, p8 for tm8 which is AAU antenna.
For NR can we get same info from antenna ports.
You can also observe the amount of SSBs.
If it is more than one, you are looking to an AAS, if it is one you continue to investigate.
Does it make sense?
BTW, Ericsson usually works with one!
Ericsson on the tests I’ve worked with also use 1SSB for n78, or scs30.
They still do beam refinement for PDSCH but only one SSB.
Not clear to me if they don’t support more or if it is only the baseline.
