How to check if intra-freq measurement for SCG cell change in NSA is done via:
- NR CSI-RS based measurement
- or via NR SS/PBCH block based measurement
If possible, I would like to configure and test both.
You can check report quantity used under meas config IE.
Usually most of vendors used ssb as of now.
On huawei 5900, is it possible to control what is used for measurement of A3?
