Hi
I’m working on an Ericsson eNodeB (DUS system) and need to change the SCTP port number, as the current port doesn’t match the MME (which uses port 36412). Could you please guide me on how to modify the SCTP port settings I’ve checked the DUS configuration but couldn’t find any parameter related to SctpPort
Hello!
Check MO SctpAssociation. There are localPortNumber and remotePortNumber can see. But its readOnly attributes… View by ‘get . sctpassociation’ command.
The port number of the local endpoint of the association.
The port number of the remote endpoint of the association.
I tried no such MO sctpassociation
Im facing a problem with dus connectivity with mme
Sctp is enable
Ike enable
Mme only disable
So from my experience Baseband you have to change ur sctpport
But dus no such a MO for that
Which MOM model that u have on DUS?
L17 q2
