How to change PCI in Ericsson?
If you have change rights, you can change PCI of site using set command, by logging through securecrt or putty.
For multiple nodes, you can use mobatch.
I am using mobaxterm.
But PCI is read only.
physiclLayerSubCellId could be changed…but not on amos but on ENM.
Yes, you have to change “physicalLayerCellIdGroup” and “physicalLayerSubCellId” through set command, and PCI (which is read only) will get changed automatically.
