Yes: Power BI can handle large data volumes. But what is the limit?
This is not an easy answer to find… and most of Power BI users have (or had in past).
This article helps you to find the answer… in a form of explanation of the various limits on Power BI dataset size and how you can know if you’re likely to hit them.
Source:
