Hello dear 5G experts,
How many Ofdm symbol per frame we need to carry L bytes PDU at Mac layer? Should the TBS be greater than L?
You need to know the number of RBs, not OFDM symbols. The TBS should be greater than (L + overhead of upper layers + 10% redundancy)
@Bannour_Ahmed
Minimum Ofdm symbols = (L*8+CRC)/codeRate/ModOrder
Where CRC is 24 or 16 depends on L, ModOrder is 2,4,6 or 8 and codeRate is typically between 0.07 and 0.93
Then you need to consider RB and slot boundaries as well as any overhead symbols within these boundaries e.g DMRS
Thank for your reply,
If we go ahead with this analysis, so in one packet the minimum Ofdm symbols we have is :
Minimum Ofdm symbols* (N_RB=12). Am I right?
No. Ofdm symbols in my analysis are not limited to one subcarrier. No need to multiply.
