Dear all.
Anyone know how many maximum ssb beams Nokia support now?
One friend said: just 6 in sub6.
Below 3 GHz Max = 4
3 Ghz to 6 GHz Max = 8
FR2 Max 64 beam
This is 3gpp standard.
Are you sure Nokia support like this?
It depends to frame structure and antenna type.
Example: tdLTE framestructure works with 8 beam beamset while semiStatic frame structure has Maximum 6 beams.
Can you explain more detail: tdlte & semistatic frame structure?
