“A congested cell doesn’t always need more capacity.”
I know that statement may sound contradictory.
After all, when we see a cell with high PRB utilization, degraded throughput, or an increase in call drops, the most common reaction is to assume that the solution is to add more capacity or even build a new site.
However, over the years, I’ve learned that a congested cell is only the first symptom.
It isn’t necessarily the actual problem.
Before thinking about a solution, I try to answer a few questions:
Is the congestion consistent, or does it only occur during certain hours of the day?
Do the neighboring cells have available capacity, or are they also saturated?
Is there a load imbalance preventing traffic from being distributed more efficiently?
Are the mobility parameters allowing users to utilize the network resources efficiently?
Is there interference reducing spectral efficiency and making the cell appear more congested than it actually is?
Have there been any recent changes in software, configuration, or traffic patterns that could explain this behavior?
Answering these questions often changes the entire conversation.
In many cases, the issue isn’t the amount of available resources.
It’s how those resources are being used.
I’ve seen operators invest in infrastructure expansion when load balancing adjustments, handover optimization, or improved interference management solved a significant portion of the problem.
That doesn’t mean capacity expansion is unnecessary.
It means it should be the conclusion of the analysis—not the starting point.
To me, network optimization has never been about reacting to a KPI.
It’s about understanding network behavior and identifying the root cause before making a decision.
Because a congested cell can tell many different stories.
The real difference lies in knowing how to ask the right questions before choosing the solution.
When you analyze a congested cell, what’s the first question you ask yourself before deciding on the next step?
