How fixed Sri help no reply from UE during eRAB setup fail?
As this means no RLF happening after reconfiguration in DL?
Can this also be due to poor RF where there is sudden erab fail, as UE is lost?
Didn’t get your point…
Are you saying that by keeping SRI fixed we can reduce ERAB failures and improve ERAB Setup Success Rate?
Generally in networks SRI change based on Cell Load, and making it Adaptive improves ERAB Setup Success Rate.
By setting SRI Adaptive eNodeB adaptively changes the SRI period for UEs based on the cell load.
This avoids SRI period reconfiguration caused by bearers with different QCIs and reduces signaling overhead.
If abnormal UEs do not send SRIs occasionally on the live network, the E-RAB setup success rate increases significantly because SRI period reconfiguration is reduced.
