How do we calculate beamforming gain?
Does anyone has any reference for this?
Beamforming gain should be included in the link curves.
It is related to number of csi-rs ports.
Higher is the number of csi-rs ports higher will be the gain.
I have seen logs with 32 csi-rs ports.
I seen beamforming gain for massive MIMO added in RS power calculation.
But I think value calculation not simple…
Yes I know.
But would need the calculation or some approximation method based on number of beams.
Think about this: Huawei can have 16 simultaneous PDSCH layers that would mean 8 beams simultaneously.
Do you mean 8 SSB LTE MU-MIMO case?
NR DL MU-MIMO case.
8 beams orthogonal to each other.
SSBs are not transmitted in same time.
But those 8 beams for PDSCH are transmitted in same time.
