Every app you use (WhatsApp, Instagram, banking) relies on one simple idea: sending information from one place to another.
But this wasn’t always easy.
Understanding how communication evolved and what makes it work is the foundation of all networks.
Explanation:
Step 1: The Core Problem
Humans always needed to communicate over distance.
But voice doesn’t travel far and physical movement takes time.
So the real challenge was:
How do we send information faster than a human can travel?
Step 2: Early Solutions
We tried:
Messengers (humans, horses, pigeons)
Smoke signals
Drums and visual symbols
They worked… but:
Slow
Limited information
High chances of error
Step 3: Electrical & Analog Communication
Then came telegraph and telephone.
Information was sent as continuous electrical signals (analog).
Problem?
Noise distorts signals
Quality degrades over distance
No reliable way to detect errors
Communication became faster, but not reliable.
Step 4: Shift to Digital
Solution: convert information into 0s and 1s (digital signals)
Why this changed everything:
Signals can be regenerated (cleaned)
Errors can be detected & corrected
Long-distance communication becomes reliable
Step 5: Birth of Data Networks
Now the problem changed again:
Not just sending, but connecting multiple devices
This led to:
Packet-based communication
Protocols
Modern networks (Internet)
Step 6: Fundamental Communication Model
No matter how advanced the network is, it always follows this:
Sender → Medium → Receiver
But internally, a lot happens:
Data: The actual information (text, voice, video)
Signal: Electrical/optical representation of that data
Encoding: Converting data → signal
Transmission: Sending signal through medium (wire, fiber, air)
Noise: Unwanted disturbance affecting the signal
Final goal: deliver data accurately and efficiently
ANALOGY
Think of communication like sending a parcel:
You (Sender) pack a message (Data)
Convert it into a shippable form (Encoding)
Use a road/air route (Medium)
Parcel faces traffic/weather issues (Noise)
Receiver gets and opens it (Decoding)
If packaging is bad → message gets damaged
If route is bad → delay or loss
Networks solve these exact problems at scale.
TAKEAWAY
Communication evolved from slow & unreliable → fast & reliable
Every network is just an advanced version of:
Send → Carry → Receive (with minimal errors)
Stage 1: Why Networks Exist → “Birth of Communication Networks”
Track: Foundations
Part 1
