Hello Experts
A question could be related to Core NW
Kindly your advice for NAT type configuration in certain SIM cards
How can we change the type of NAT from device settings?
The issue was that some SIMs have Type 2 and others Type3
How can we change this?
It is affecting gaming.
Hello @Atbarawi .
What you mean?
Static / dynamic ?
Or pat / nat ?
Usually NAT is done on FW after PGW to convert dynamic IP address is allocated by PGW to public paid IP address to use in Internet.
It is related to certain SIM cards configured with this NAT TYPE 3 which affect the gaming cause of the security features.
Customer cannot change the NAT type.
So thats why I want to know in which node this NAT type is configured?
Core network.
You can change it via PC.
In this link you can see explanation:
Your PS4 will get lousy connection when the it is in NAT Type 3 and you need to change it. This is a detailed guide showing you how you can check NAT Type setting on your PS4 and how your need to configure your router to change the NAT type.
Est. reading time: 4 minutes
