I’m not going to sugarcoat this. Living in a rural area with bad internet is genuinely frustrating, and if you’ve found this post, you probably know that feeling.
I’ve spent the last few years trying basically everything available in my area. This is just my honest experience. No sales pitch. Just what worked, what didn’t, and what I would tell a neighbor if they asked.
The Struggle Was Real From Day One
When we moved out here, I thought the internet would be fine. It might be a little slower than in the city. No big deal, right? Wrong.
The first provider we tried was a local DSL service. On a good day, we got maybe 8 Mbps down. On a bad day, which was most days, pages took forever to load. Video calls were a joke, and streaming anything after 7 PM was impossible when everyone in the area was apparently online at once.
We tried a second provider. Same story, different name on the bill.
Working from home became stressful. My partner and I couldn’t both be online at the same time without one of us getting disconnected. Kids doing homework online? That led to a whole new argument every evening.
What I Tried Before Finding Something That Actually Worked
Here’s the honest rundown of everything we tested:
DSL — Cheap, but very slow and inconsistent. Fine for basic email, useless for anything else.
Fixed Wireless (local provider) — Better than DSL but heavily dependent on weather and line of sight. One stormy week, and we were basically offline.
Mobile Hotspot (major carrier) — Hit our data cap within two weeks, then got throttled. Not a real solution unless you only use the internet rarely.
Satellite (older generation) — The latency made it unusable for video calls or other real-time applications. Gaming was out of the question, and streaming was constantly buffered.
Every single option felt like a compromise. It seemed like rural living meant accepting bad internet as part of the package.
Then Someone in a Local Facebook Group Mentioned UbiFi
I’ll be honest, I was doubtful. At that point, I had been let down enough times that I didn’t trust any internet provider claiming to serve rural areas.
But a neighbor had been using UbiFi for a few months and could not stop talking about it. So, I decided to check it out.
UbiFi works differently from what I had tried before. It operates on 4G LTE networks, the same cell towers your phone uses, but it is specifically designed for home internet in rural and underserved areas. There’s no satellite lag, no strict data limits like a mobile hotspot plan, and you don’t need a clear line of sight to some tower on a hilltop.
The setup was easy. The equipment arrived, I plugged it in, and it just worked. This honestly felt suspicious after everything I had been through.
My Actual Experience Using It Day to Day
A few months in, here’s what I can say genuinely:
Video calls are stable: My partner and I can both be on calls at the same time without either of us getting dropped. That alone made switching worthwhile.
Streaming works: We watch Netflix most evenings without buffering. It’s not always in 4K depending on the time of day, but it’s consistently watchable, which is more than I could say before.
Latency is noticeably better than satellite: This is more important than people realize. Low latency means pages load quickly, video calls don’t have that strange delay, and real-time apps actually feel real-time.
It’s not perfect: Signal strength varies depending on how close you are to a 4G tower and how busy your area is. There have been slower evenings. I’m not going to pretend it’s fiber.
What I’d Tell Anyone Considering Rural Internet Options
Don’t assume that the first or cheapest option is your only choice. Rural internet now offers more options than it did even three years ago. What works best depends on your specific location and how you use the internet.
If you work from home, low latency is more important than just high download speed. A connection that consistently delivers 25 Mbps with low latency will feel better day to day than a 50 Mbps connection that frequently spikes and drops.
Check the actual cell coverage at your address before committing to any service. This simple step could save you months of frustration.
And talk to your neighbors. Local Facebook groups, community boards, and forums are often more helpful than a provider’s website. Real people in your area can share what works well and what sounds appealing in ads but doesn’t perform as promised.
Bottom Line
Rural internet remains a challenge without one clear solution. What worked for me might not work for you. It depends on your location, how many people are using the service, and your specific needs.
If you’ve already tried DSL and standard satellite but are still having issues, and if you have decent 4G coverage in your area, consider options like UbiFi. This suggestion is not based on marketing hype but on the fact that LTE-based home internet has improved significantly. Many people in rural areas might not even know this is an option.
Feel free to ask me anything in the comments. I’m happy to share more about my setup or answer any questions you have before you sign up for anything.
