Dear All
I have observed a significantly high number of normal releases in the network and would like to ask whether I should check the DRX paging policy, considering that we have IMS VoLTE and the inactivity timer is still set to 10 seconds.
try and impliment MT call IMS pre-paging(sip options) and PCSCF restoration for certain cause sip cause codes as well as Rx experimental results codes.this will improve any MT success rate issues for you.
