Hello All.
Do you have reference values for downlink and uplink activity factor, for both regular mobile users and FWA?
Values for capacity calculations.
We are taking 80% activity factor for FWA for both DL and UL.
It’s empirical value.
Wow, that’s pretty high!!
Your calculation is the ratio between RRC_CONNECTED / ACTIVE_USERS?
Or other way around?
Yeap…When I was working with this kind of network (FWA) my range was from 75% to 80%.
I think you can consider 20% for mobile Active/subs and 75% FWA active/subs.
FWA average throughput session will depends of IP data speed package, but you should expect something close to 800 kbps what is A LOT!
Yes, take total users, connected users and active users for busy hour calculation.
80% for safer side and also check 5G package type.
It is on GBR / non GBR and their limit subscription.
Do you know the inactivity timer in this Network where you got your data?
Same for you: do you know the inactivity timer value?
10 seconds.
Great, 10 seconds is what I’m seeing for a LTE NW too.
