Hi All,
In 5G Fixed wireless acess, CPE antenna quality makes a massive difference on performance and TCO.
Telcos using high gain Antennas can improve 20% coverage area and generate up to 25% spectral efficiency, which means more subscribers per site.
From a Capex perspective, this means a higher cost of CPE but a lower cost per site, which in the aggregated case implies up to 40% lower Capex.
With a high quality antenna we can reach high DL throughput (Mbps) even distant (meters) from CPE.
High Quality Antenna benefits
- Consistent higher throughput
- Consistent better radio efficiency - capacity
- Better coverage
