Hello 5G Experts,
From which message can we get bandwidth part (BWP) in 5G?
And assuming BWP is the only active BW a Ue uses per carrier, how to interpret an UE served with 4 CA with each carrier of 100 MHz BW will the use 4x BWP or 4xCA BW = 400 MHz?
For DL it’s PDSCH config, and for UL it’s PUSCH config.
Only one active BWP possible but 4 can be configured.
4 x CA BW = 100 MHz.
Csi-rs ports are given to improve coverage by increasing SINR.
If you reduce csi-rs ports beam gain will reduce so SINR will be reduced.
I think you didn’t get my question.
4 x CA each CC having it’s own BWP.
In this case I shoul take 100 MHz as BWP since17875 corresponds to 100 MHz BW?
