One of the best best DevOps course for Beginners.
You can learn DevOps but more importantly - video make it easy to understand the concepts that everyone should understand and where they fit in the ecosystem of Software Development.
For example, you’ll see entire workflow of ci/cd and understand how it works.
What is DevOps in the context of software engineering? Learn all about DevOps in this comprehensive course for beginners with three technical tutorials. You will learn what DevOps is, continuous integration, continuous deployment strategies, and application performance management. Many DevOps practices are commonly used in programming and web development, it is important to understand key terms and technologies.
This course often references the MERN (MongoDB, Express JS, React JS, Node JS) technology stack. You will get a series of talks with technology recommendations based on these best practices. There will be several programming examples embedded in these talks. As long as you know the absolute basics of coding and the web, you’ll have no problem following along.
