Folder Size
Introduction
You can not understand why Windows does not come with this option - the Mac has: view the folder size.
When we visualize the files and folders in Windows Explorer, only got to see on our right the size of each file - the size of directories appear empty. To solve this problem, we can use the Folder Size, which we know today.
Why Use the Folder Size
The Folder Size is a program that adds a new column to the Details view in Windows Explorer. The new column shows not only the size of the files, but also the size of directories. The sizes of each directory are calculated, and you may know, for example, which is occupying too much space, helping in cleaning tasks and backup. Now that you know that this information might be available, will not want to be without use when needed.
Installation and License
installation Folder Size is trivial, and the program is free. Download the installation program from the Internet, and proceed with the default installation.
Program Site: http://foldersize.sourceforge.net/
Program Interface
The program has no interface itself. It’s very simple, and you can check it in action simply by opening Windows Explorer.
To view the new columns, simply click the right button (1) details on the top bar and select Folder Size. The size of each directory can now be seen on the Folder Size column (2), as well as the amount of sub-directories (column Folder Children) and Files (File column Children).
This is an interesting program, IF you do use it. Thus, we recommend to install it when you need it, and remove when no longer needed. Just to let Windows as free as possible. To remove, simply login Remove Programs in Control Panel.
Conclusion
This was a brief summary of the software Folder Size. This is a small program to show the size of the directories directly in Windows Explorer view option details.
