Finding / Accessing the Console port on Nokia AirScale ASIB
Hi everyone,
I’m currently working on a Nokia AirScale ASIB (AirScale Common Plug-in Unit) and I need to access the serial/console interface for troubleshooting/local management.
I know these modules usually rely on the LMP (Local Management Port) via an RJ-45 Ethernet cable using the default IP 192.168.255.126 for SSH/Web access.
However, I am looking for the actual hardware Console/Serial port connection specs.
  • Is there a specific proprietary pinout on the RJ-45 LMP port that forwards RS-232/Serial signals (like a Cisco rollover cable pinout)?
  • Or is there a hidden/internal serial header on the board that requires a USB-to-TTL adapter?
  • If anyone has the exact baud rate settings (e.g., 115200 8N1) and pinout for a direct console connection to the ASIB bootloader/kernel, that would be amazing.
Any documentation, pinout diagrams, or tips from anyone who has successfully unbricked or consoled into an ASIB board would be greatly appreciated!
Thanks in advance for your help!
