Field Tools: How I Structure a Live 5G Drive Test
Urban drive testing isn’t just “watching numbers move”, It’s structured observation.
Here’s how I typically approach a live 5G NSA/SA drive test session using G-NetTrack:
:one: SERVING CELL – What am I really connected to?
:small_blue_diamond:Band combination, PCI, ARFCN, RSRP/RSRQ/SNR.
:small_blue_diamond:Before analysing behaviour, confirm the serving cell.
:two: NEIGHBOUR CELL – Who’s waiting in the wings?
:small_blue_diamond:Mobility starts here.
:small_blue_diamond:Neighbour cells stats for reselection or handover.
:three: LOCATION MAP – Where does RF meet geography?
:small_blue_diamond:Urban clutter, reflections, elevated roads, tunnels.
:small_blue_diamond:Overlaying measurements on the map reveals patterns you won’t see in raw logs alone.
:four: SIGNAL INFO – Stability over time
:small_blue_diamond:Short spikes are noise.
:small_blue_diamond:Sustained degradation is a pattern.
:small_blue_diamond:Trend view exposes what averages hide.
:five: DRIVE – Capture everything
:small_blue_diamond:If it isn’t logged, it didn’t happen.
And when needed, controlled voice/data sequences can be triggered to make behaviour repeatable not just anecdotal.
Tools don’t replace engineering judgement, they give you visibility so you can apply it.
