it posibble edit external alarms remotely, i need edit problem text
for example edit text : door open , open door for 1 tag THE-OPEN-DOOR
Hi, @Kiasz_Gomez, it depends on the type of equipment you use (DUG, DUW, BaseBand, BSC).
Thank you for the response. We have the 4 types of equipment (DUS, DUG, DUW, BaseBand, and BSC). However, the majority are BaseBand and BSC. Could you please provide examples of these 2, and if possible, the rest?
@Kiasz_Gomez no problem
BaseBand
Launch AMOS, then get the alarm port with slogan like door
BaseBand> get AlarmPort alarmSlogan door
230823-06:37:37 10.10.10.10 21.0n MSRBS_NODE_MODEL_21.Q2_510.27869.133_da13 stopfile=/tmp/17783
MO Attribute Value
FieldReplaceableUnit=BB-1,AlarmPort=6 alarmSlogan DOOR
Total: 1 MOs
Block port
BaseBand> bl FieldReplaceableUnit=BB-1,AlarmPort=6
Block following 1 MOs ?
238 Equipment=1,FieldReplaceableUnit=BB-1,AlarmPort=6
Block 1 MOs. Are you Sure [y/n] ? y
Id MO administrativeState Result
238 FieldReplaceableUnit=BB-1,AlarmPort=6 0 >>> Set.
Total: 1 MOs attempted, 1 MOs set
Change slogan
BaseBand> set FieldReplaceableUnit=BB-1,AlarmPort=6 alarmSlogan OPEN DOOR
230823-06:38:00 10.10.10.10 21.0n MSRBS_NODE_MODEL_21.Q2_510.27869.133_da13 stopfile=/tmp/17783
Set alarmSlogan on following 1 MOs ?
243 Equipment=1,FieldReplaceableUnit=BB-1,AlarmPort=6
Set alarmSlogan on 1 MOs. Are you Sure [y/n] ? y
Id MO alarmSlogan Result
243 FieldReplaceableUnit=BB-1,AlarmPort=6 OPEN DOOR >>> Set.
Deblock port
BaseBand> deb FieldReplaceableUnit=BB-1,AlarmPort=6
Deblock following 1 MOs ?
238 Equipment=1,FieldReplaceableUnit=BB-1,AlarmPort=1
Deblock 1 MOs. Are you Sure [y/n] ? y
$netconf_pid = 18677
238 FieldReplaceableUnit=BB-1,AlarmPort=1 1 >>> Set.
BSC
Connect to APG, then go to external alarms
>ManagedElement=BSCNAME,SystemFunctions=1,AxeFunctions=1,SupervisionHandling=1,ExternalAlarmReceiverM=1
(ExternalAlarmReceiverM=1)>show all
ExternalAlarmReceiver=18
additionalAlarmSlogan="TEMPERATURE IS HIGH"
administrativeState=UNLOCKED
alarmCondition=OPEN_CIRCUIT
alarmSeverity=ALARM_HIGH
alarmSlogan="T-HIGH"
alarmSource=EXTERNAL
alarmState=false
ExternalAlarmReceiver=17
additionalAlarmSlogan="DOOR"
alarmSlogan="DOOR"
alarmState=false
(ExternalAlarmReceiver=17)>
Enter configure mode and change slogan
(ExternalAlarmReceiver=17)>configure
(config-ExternalAlarmReceiver=17)>administrativeState=LOCKED
(config-ExternalAlarmReceiver=17)>commit -s
(config-ExternalAlarmReceiver=17)>alarmSlogan="DOOR IS OPEN"
(config-ExternalAlarmReceiver=17)>administrativeState=UNLOCKED
DUW/DUS
Almost the same as BaseBand
