This single visualization beautifully captures the soul of 5G Physical Layer β from modulation to coding to throughput performance ![]()
Breakdown of Whatβs Happening:
- QAM Signal Generation β Each symbol carries multiple bits.
- Constellation Diagram β Represents how symbols are mapped in I/Q space (here, 4-QAM = 4 symbols).
- BER Performance β As SNR increases, bit errors drop sharply
- LDPC Encoding β Used for Data Channels (high reliability, high throughput).
- Polar Coding β Used for Control Channels (optimized for short block lengths).
- Throughput vs SNR β Higher SNR = Better modulation efficiency.
- Coding Gain & 5G MCS Table β Shows trade-offs between rate and reliability.
Key Insight:
5Gβs power lies in adaptive modulation and coding (AMC) β dynamically choosing the best modulation and code rate depending on channel conditions.
Thatβs how your phone maintains both speed
and stability
even when you move or signal fluctuates!
