Ericsson NR FDD DSS to clean carrier of NR FDD
Hi All,
I have a Ericsson node where LTE700 and NR 700 configured with DSS. I wanted to block LTE 700 for a test case, but when I block LTE 700 cell it is impacting NR 700 as well due to dss. Is there anyway that I can block the lte 700 and it won’t impact NR700? Do I need to disable dss for this?
Of you have nsa 5g fdd , then you can’t lock fdd lte , because it is anchor and your 5g will be down
