Hi All,
Please let me know how do we take Ericsson Radio node (BBU) dumps in XML format from ENM. I am aware of kget all and dcgk. Just wanted to know if there is another way to take dump in XML format. Please suggest.
Hi All,
Hi, @Sooraj, here are couple approaches:
cliappcmedit export --ne RBSNAME1 --filetype 3GPP --filecompression none
curl -i -X POST \
-H "Content-Type:application/json" \
-b ENM_cookie.txt \
-d \
"type": "EXPORT",
"configName": "Live",
"fileFormat": "3GPP",
"dataCategories": ["ENM_DATA", "NETWORK_RESOURCE_DATA"],
"userFilter": {
"value": "STN.*;TGTransport.*;SuperChannel.*;"
"nodeSearchCriteria": {
"nodeSearchScopes": [{
"scopeType": "FDN",
"matchCondition": "EQUALS",
"value": "SubNetwork=ONRM_ROOT_MO,SubNetwork=TCU",
"neType": "TCU02"
"compressionType": "NONE",
"enumTranslate": "true",
"syncState": "SYNC",
"jobName": "ExportWithUserDefinedFilter1",
"prettyFormat": "true"
'https://enm.example.com/bulk/export/jobs'
Thank you. How will I get to know the status of this Job ID and download the same? Please suggest.
cmedit export --status --job 31160
cmedit export --download --job 31160
Thank you so much.
