Hello Experts,
Can anyone assist with the setup for ericson Node Manager?
What do you want to know?
To access an announcement on the MGW
Hi King,
I know that but I was asking whats the issue you were facing?I hope do you have the cpi documentation follow the guide.And importantly open all the comes related to CORBA interface between MRS and jump server. And keep tha java version to 1.8 dont update,if you do those two it is a smooth installation I am afraid. I did it very recently in a redhat environment so you can ping me if you are facing any specific issues.
Thank you
Kind regards
Isuru
Install the Node Manager software on the server. Configure the network connections so Node Manager can communicate with your Ericsson base stations. Add your nodes into the manager inventory (IP, name, credentials). Set up alarms and notifications to the appropriate team. Test by triggering a node fault and verifying it shows up in the manager.
Did you able to get it done?you have to use security mode 1 if you are installing it without the support of ENM.thanks
