Can you run this in online mode also? or you guys using it in offline mode.( just feed the downloaded logs)
Moshell 25 & 24 Moshell - Google Drive
Link expired yesterday. Any update? Thank you!
hey mate. please upload again that files or even newest version maybe you have. i really need it. thanks a lot
Any one please share letest moshell file.
Please. share agane
Does anyone have Moshell 26? Please share it if you can. Thank you
link died, can u reshare link? tks
Moshell26.0a
Did you verify gawk is installed? It is not installed by default. If the command which gawk returns nothing, then:
sudo apt install gawk
If anyone is able to access this download link, please reup on mega.nz or similar for the rest of us! ![]()
Gawk is in /usr/bin/gawk
Aha! It looks like the moshell package ships with gawk binaries for x86_64 linux, MacOS and Windows. The moshell installer picks the gawk binary that works with your system and renames it for future use. Your RPi5 is aarch64, so not compatible with any of the included gawk binaries. Unfortunately, it looks like the moshell installer does not support your architecture. With some modification, you could make the moshell installer use your distro provided gawk. Just doing a symlink after running the installer won’t be enough because the installer itself uses gawk to make a bunch of text substitutions in various included files.
Probably best to start a new thread for this if you want further assistance.
Message in a private group or channel.
This link will only work if you are a member.
Moshell26.0a
Very much appreciated for sharing
Perfect boss you the best, i’m on one. yeah!!! thanks for the post i’m new here need a perfect teacher to train me more.
