[Ericsson] ENM: Query syntax for saved searches with multi-level MOs
Does the saved search in ENM support multiple-level MO rules?
example:
SubNetwork=Area1,SubNetwork=Sub1,MeContext=LN123456,NetworkElement=LN123456
Save Search
select all objects of type NRCellDU has attr secondaryCellOnly = false has parent GNBDUFunction has parent MangedElement hsa attr dnPrefix = "*SubNetwork=Area1*"
vlr9999
Hi, @1118, yes, check search syntax
select all objects of type NRCellDU where NRCellDU has attr secondaryCellOnly = false and NRCellDU has parent GNBDUFunction and GNBDUFunction has parent ManagedElement and ManagedElement has attr dnPrefix = "*SubNetwork=Area1*" from node type RadioNode
@vlr9999 thanks you reply let me try it on next working day.
The saved search syntax seems to search only at the parent level, rather than at the child level.
My goal is to find all NetworkElement instances within a SubNetwork where secondaryCellOnly = false.
Hi, @1118, I checked on my network and it is return all nr cells with false
