Ericsson DUW RAN IP address changing
Dear experts,
I am trying to change the IP address of the OAM and IUB in the Ericsson DUW, but when changing the IUB IP address, the subnet mask field is not allowing me to change it as per the design, whereas for OAM I was able to change it. I need your support to make this happen.
Hi, @Mani, to change IUB address you need to delete all related objects and recreate it.
Hi, Thanks for your response. Is it possible to do it through Element Manager?
@Mani, yes, it is possible, but it is pain. You need to remove sync references, then delete sctp, hostet, ipinterface.
