Hi
How can I create Ericsson Bulk CM files (XML or GZ) that I can later upload to TEMS Discovery in the Import Network Configuration tab? Any special command in CLI? I’ve tried “cmedit export -n * --filetype 3GPP” and this file doesn’t work…
Hi
cmedit export --ne SubNetwork=ONRM_ROOT_MO,SubNetwork=LTE --filetype 3GPP --prettyformat true --jobname myjobname --filecompression gzip
and of course you can customize which ne to export
Thanks I will try this tomorrow ![]()
Ok, and what about TEMS cell reference file *.cel? How to get this file?
Those files commonly called cellfile, you have to create them yourself with your network information. I believe TEMS Discovery itself brings some example files.
