I would like to know if we can see gateway IP defined in BSC for AOIP of BSC.
From IHCLP command I was able to get LIP BSC and RIP MSC for all SAID. I would like to know if default IP can be also seen from BSC for LIP or it will be defined only in router to which BSC is connected?
Thank you. Can you please let me know how to check from SMXB? I use shell terminal to login to BSC. Once I login to BSC will I be able to see SmXB config?
Thank you. I was able to get details. Please tell how will I go back to main menu of transport of APG? When I give exit, it takes me to CP. Then again I need to login APG.
