To Ericsson Experts,
Is anyone using Baseband 6648 in there network with Mixed Mode LTE + NR ?
Hello Vikas,
If you don’t already have a 6630, then would assume you would use 6648 in both modes unless the massive MIMO part eats up all the resources. Is this something the operators in India are looking at?
Earl
Hello, Yes, it is possible to make this configuration, I have personally done it on a few occasions.
hello, may I ask what is there a difference between 6630 and 6648? in terms of cost and functionality. Thank you.
