Indoor Unit (IDU)
Function: Processes baseband signals and converts them to Intermediate Frequency (IF).
Purpose: Acts as the central control unit for modulation/demodulation and network interfacing
Outdoor Unit (ODU)
Function: Converts IF signals from the IDU to Radio Frequency (RF) for transmission.
Purpose: Mounted near the antenna to reduce signal loss and amplify RF signals
Antenna
Function: Radiates and receives microwave signals.
Types:
- Parabolic Dish Antenna (high gain for long distances).
- Flat Panel Antenna (compact for short links).
- Grid Antenna (lighter, used in medium-range links)
IF Cable (Intermediate Frequency Cable)
Function: Connects the IDU to the ODU, carrying IF signals and DC power.
Purpose: Ensures seamless communication between indoor and outdoor units
Coupler
Function: Splits or combines microwave signals with minimal loss.
Purpose: Allows signal redundancy or distribution for multiple ODUs
Orthomode Transducer (OMT)
Function: Combines and separates signals of two polarizations (vertical and horizontal).
Purpose: Increases link capacity without increasing spectrum usage
Waveguide
Function: Carries RF signals between the ODU and antenna with low signal loss.
Purpose: Used in high-frequency setups to maintain signal integrity
Power Supply Unit (PSU)
Function: Provides DC power to the IDU and ODU.
Purpose: Ensures continuous operation of the system, often includes battery backup
Alignment Tools
Function: Ensures precise antenna alignment for optimal signal performance.
Types: GPS-based tools, optical alignment scopes, signal analyzers
E-Band Radio (70/80 GHz)
Function: Provides ultra-high-capacity short-range links.
Purpose: Ideal for urban backhaul and data center connections with multi-Gbps capacity
Universal Backhaul Radio (UBR)
Function: Multi-band radio for wireless backhaul applications.
Purpose: Provides connectivity across various frequency bands (6–42 GHz)
Network Management System (NMS)
Function: Software to monitor and manage the microwave link.
Purpose: Enables real-time performance tracking and fault detection
Mounting Hardware
Function: Secures antennas and ODUs to towers, rooftops, or poles.
Types: Brackets, clamps, and mounting kits for stability and alignment
Surge Protector
Function: Protects the microwave link equipment from lightning strikes and power surges.
Purpose: Ensures system safety and reliability
Safety Rod
Installed at the highest point of the antenna structure (towers, poles, rooftops).
Used in microwave communication systems, especially in areas prone to thunderstorms.
