Core network team say they have a lot of enodeB response timeouts on their pdp activation failure traces.
What is the timer responsible for waiting for feedback from enodeB in core network?
what are pontential causes of enodeb response time outs aside from transmission?
Hi Please ask from core core guy enodeB details which are major contributing in it.
Normally enodeB response timeouts leads to degrade in LTE attach success rate.
There could be major three reason if it starts suddenly even you did not change any radio side.
Alarm pop up on enodeB related to RSSI or any other fault in antenna which can also impact on other technology.
Check the users and traffic of sites if its overloaded
Issue may persist with Transmission media if any link is going congested for those particular sites.
If eNB timer waiting for UE response is longer than the core timer waiting for eNB response, then any radio issue will be captured by core timers first
