Does anyone know the ENM command for an eNodeB to check the number of users per MME?
(Ericsson vendor)
Try using pmx fdd S1
This will display all S1-related counters.
However, I don’t have information on specific ones.
What do you mean?
To check the number of users per cell, use:
ue print -admitted
I want to check how many users the eNodeB is assigning to each MME.
The MMEs are unbalanced, with 90% on the MME and only 10% on the vMME.
I need to analyze how the eNodeB is distributing users across the different MMEs.
I will try… thanks.
Hi @b50ft . You may try amos and coli command /tn/tnrh-session. If you know which SGW IP-addresses relate to which MME, then you may estimate how many tunnels (UE) are served by each MME based on remoteIpAddress from command printout.
Verify the termPointToMME
I believe that is a Core Network KPI.
