Any idea on how EMF exposure is calculated in MASSIVE mimo?
What is the maximum EMF (V/m)for massive mimo antennas and how it is determined ?
From site a site design perspective… to be on the safe side you can use simply
Max TX power * Max antenna array gain for traffic beam = EIRP. From EIRP you can get your V/m.
Then there are more advanced techniques(vendors), such as averaging power traffic profiles over time, power lock etc.
