DSP Is the Real Differentiator in Coherent Optics
๐—ฉ๐—ฒ๐—ป๐—ฑ๐—ผ๐—ฟ ๐——๐—ฆ๐—ฃ ๐—–๐—ผ๐—บ๐—ฝ๐—ฎ๐—ฟ๐—ถ๐˜€๐—ผ๐—ป
WL6 vs ICE-X vs PSE-6s
At 100G and below, fiber quality dominated performance.
At 400G and beyond, ๐——๐—ฆ๐—ฃ ๐—ฏ๐—ฒ๐—ต๐—ฎ๐˜ƒ๐—ถ๐—ผ๐—ฟ ๐—ฑ๐—ฒ๐—ฐ๐—ถ๐—ฑ๐—ฒ๐˜€ ๐˜„๐—ต๐—ผ ๐˜€๐˜‚๐—ฟ๐˜ƒ๐—ถ๐˜ƒ๐—ฒ๐˜€ ๐—บ๐—ฎ๐—ฟ๐—ด๐—ถ๐—ป๐—ฎ๐—น ๐—น๐—ถ๐—ป๐—ธ๐˜€.
This is where vendor differences quietly matter even when datasheets look similar.
Letโ€™s talk reality.
:right_arrow: Ciena WaveLogic 6 (WL6)
Strength: ๐—ฆ๐˜๐—ฎ๐—ฏ๐—ถ๐—น๐—ถ๐˜๐˜† ๐—ผ๐—ป ๐—ถ๐—บ๐—ฝ๐—ฒ๐—ฟ๐—ณ๐—ฒ๐—ฐ๐˜ ๐—ณ๐—ถ๐—ฏ๐—ฒ๐—ฟ
WL6 is engineered for real networks, not pristine labs.
Key characteristics:
โ€ข Strong tolerance to OSNR variation
โ€ข Conservative constellation stability
โ€ข Excellent survivability through ROADM chains
โ€ข Predictable behavior on legacy G.652 and G.655
โ€ข Designed with long-haul and subsea realities in mind
WL6 prioritizes survivability over headline efficiency.
That is why it performs consistently on APAC routes with mixed fiber quality.
:right_arrow: Infinera ICE-X
Strength: ๐—–๐—ฎ๐—ฝ๐—ฎ๐—ฐ๐—ถ๐˜๐˜† ๐˜„๐—ถ๐˜๐—ต ๐—ณ๐—น๐—ฒ๐˜…๐—ถ๐—ฏ๐—ถ๐—น๐—ถ๐˜๐˜†
ICE-X balances reach and spectral efficiency.
โ€ข Flexible baud and modulation profiles
โ€ข Good spectral utilization
โ€ข Strong metro and regional performance
โ€ข Scales well on modern fiber and controlled environments
ICE-X rewards good optical hygiene.
It shines when the fiber plant is known and engineered,
but is less forgiving of sloppy amplification and tilt.
:right_arrow: Nokia PSE-6s
Strength: ๐—ฃ๐—ผ๐˜„๐—ฒ๐—ฟ ๐—ฎ๐—ป๐—ฑ ๐—น๐—ผ๐—ป๐—ด-๐—ต๐—ฎ๐˜‚๐—น ๐—ฟ๐—ฒ๐—ฎ๐—ฐ๐—ต
PSE-6s is built for high-power coherent transport.
โ€ข Strong launch power handling
โ€ข Solid long-haul performance
โ€ข Robust DSP and FEC integration
โ€ข Effective on disciplined backbone spans
PSE-6s performs best where amplification strategy is deliberate.
It benefits from careful power management and well-designed spans.
๐—ง๐—ต๐—ฒ ๐—›๐—ฎ๐—ฟ๐—ฑ ๐—ง๐—ฟ๐˜‚๐˜๐—ต ๐—˜๐—ป๐—ด๐—ถ๐—ป๐—ฒ๐—ฒ๐—ฟ๐˜€ ๐—”๐˜ƒ๐—ผ๐—ถ๐—ฑ
๐—ก๐—ผ ๐——๐—ฆ๐—ฃ ๐˜ƒ๐—ถ๐—ผ๐—น๐—ฎ๐˜๐—ฒ๐˜€ ๐—ฝ๐—ต๐˜†๐˜€๐—ถ๐—ฐ๐˜€.
๐—•๐˜‚๐˜ ๐˜€๐—ผ๐—บ๐—ฒ ๐——๐—ฆ๐—ฃ๐˜€ ๐˜๐—ผ๐—น๐—ฒ๐—ฟ๐—ฎ๐˜๐—ฒ ๐—ฎ๐—ฏ๐˜‚๐˜€๐—ฒ ๐—ฏ๐—ฒ๐˜๐˜๐—ฒ๐—ฟ ๐˜๐—ต๐—ฎ๐—ป ๐—ผ๐˜๐—ต๐—ฒ๐—ฟ๐˜€.
On marginal links:
โ€ข One DSP flaps
โ€ข Another survives
โ€ข A third forces modulation downshift
Same fiber. Same OSNR reading. Different outcomes.
That difference is ๐——๐—ฆ๐—ฃ + ๐—™๐—˜๐—– ๐—ฏ๐—ฒ๐—ต๐—ฎ๐˜ƒ๐—ถ๐—ผ๐—ฟ, not marketing.
๐—ง๐—ฎ๐—ธ๐—ฒ๐—ฎ๐˜„๐—ฎ๐˜†
DSP selection is not about:
โœ˜ Max Gbps
โœ˜ Lab OSNR numbers
โœ˜ Datasheet reach
It is about:
:check_mark: Tolerance to OSNR drift
:check_mark: Stability under nonlinear penalties
:check_mark: ROADM survivability
:check_mark: Behavior on aging fiber
In APAC networks, forgiveness beats aggression.
๐—™๐—ถ๐—ป๐—ฎ๐—น ๐—ง๐—ต๐—ผ๐˜‚๐—ด๐—ต๐˜
If you do not factor DSP behavior into vendor selection,
you are gambling your network on assumptions not engineering.
And physics always collects.
At higher speeds, especially 400G and above, real-world performance is less about headline specs and more about how the DSP behaves on imperfect fiber. WL6 favors stability and survives messy, legacy networks. ICE-X delivers strong capacity when the fiber plant is well controlled. PSE-6s excels on carefully engineered long-haul links. On marginal paths, DSP and FEC behavior determine whether a link survives, flaps, or downshifts.
