Do you know how a VLAN works?
:globe_with_meridians: In a regular switch, all connected devices share the same “conversation room” - the broadcast domain.
A VLAN (Virtual Local Area Network) is like building invisible walls inside that switch, creating separate logical networks within a single physical device. Devices in different VLANs cannot see each other, even if they are connected to the same switch.
:gear: The magic happens through a 12-bit tag (0–4095) inserted into the Ethernet frame header, defined by the IEEE 802.1Q standard.
When a frame enters a VLAN-configured switch, the switch inserts this tag to identify which VLAN it belongs to.
Switch ports can operate in two main modes:
Access ports – belong to a single VLAN and do not expose VLAN tags to end devices.
Trunk ports – carry multiple VLANs simultaneously, preserving the tags (typically used between switches or between a switch and a router).
:magnifying_glass_tilted_left: Think of a building:
VLAN 10 – Guests (public Wi-Fi)
VLAN 20 – Employees (corporate network)
VLAN 30 – Security cameras (IoT)
All traffic flows through the same cables and switches, yet each network remains isolated. This improves security, reduces broadcast traffic, and provides logical organization.
:rocket: Communication between VLANs requires a Layer 3 device (router or Layer 3 switch).
One classic design is called “router-on-a-stick.”
In this setup, a single physical trunk link connects the switch to a router. The router uses virtual interfaces (SVIs or subinterfaces), one per VLAN, to route traffic between them while enforcing security policies such as ACLs.
:compass: VLANs are a foundational element of modern network segmentation. They allow a single physical infrastructure to support multiple purposes, isolated test environments, and granular access policies.
They are also one of the first steps toward Software-Defined Networking (SDN).
:books: Reference: IEEE 802.1Q – Virtual Bridged Local Area Networks.
Which concept do you find more impactful in network design: VLANs, VPNs, or Subnets?
