Hi dears,
Do you have any idea reagarding this sentences in LTE?
There is a probability that the transmit power of some subframes exceeds the expected maximum transmit power. This function must be disabled in countries or regions where the instantaneous power is prohibited from exceeding the power limit.
When you run an MML command to change this option setting, a message will be displayed, indicating that the modification will have severe impact on the system. Cell services will be interrupted if you change this option setting during network operation.
I want to know how can we disable this function.
