For ENDC, you still have to monitor 5G and 4G PDCP and PDSCH separately, and if your PDCP entity is 5G the PDCP throughput you can measure at 5G alone and PDSCH still need to be probed from both due to split bearer.
Thanks let me check for split bearer case.
Some confusion as per understanding at 5G end RLC throughput to be monitor if data split at 5G PDCP layer…
DL data flow option there to control, i.e. dldataoverf1 or dldataoverf1x2.
This one commonly used.
Yes, correct.
In ENDC call flow, is it mandatory to have dedicated bearer if SRB3 enabled?
Dedicated bearer is not mandatory, with or without SRB3.
Here App thrpt (avg) is the highest whereas it was mentioned that this layer will have lowest throughput.
App layer is in kbps ….others are given in Mbps
