In RF optimization, we often assume issues come from coverage, interference, or parameter tuning.
But sometimes, the real problem is much simpler:
The antenna is pointing in the wrong direction.
The challenge?
Cross feeder is not hard to understand, but it is difficult to detect at scale.
Detection still relies on:
β’ Manual analysis
β’ Repetitive validation
β’ Time-consuming investigation
Result:
Issues go unnoticed
Or worse misdiagnosed
When does it happen?
Often during normal activities:
β’ Hardware Expansion / sector addition
β’ Swap BTS / Antenna modernization
β’ Maintenance / re-connection
β’ MOCN / MORAN deployment
β’ Network rollout / upgrades
Not a rare issue, but a byproduct of network evolution
Case observed:
A sector with normal RSRP, but unstable KPI.
From MR dominant cell distribution:
Coverage β azimuth
User distribution shifted direction
Strong indication of cross feeder
What the data reveals:
Without field visits, cross feeder can be detected from:
β’ User distribution patterns
β’ Handover behavior
β’ Interference relationships
All derived from MR & network statistics.
Traditionally, this requires specialized systems (SON-based),
which are not always flexible or accessible for all teams.
Domino Effect:
KPI degradation
HO failure & dropped calls
Increased interference
Load imbalance
Higher retransmission β lower throughput
Leading to wrong optimization decisions
Operational & Business Impact:
Longer troubleshooting cycles
Inefficient drive tests
Poor user experience
Increased complaints & churn risk
A different approach:
With Azimuth Validator (QGIS-based):
Detect suspect sectors quickly
No manual sector-by-sector analysis
No initial drive test
Predict actual antenna direction
Field visits become targeted & efficient
Scalable for Tier-1 operator environments:
β’ Thousands of sectors
β’ Reduced manual effort
β’ Faster optimization cycles
Cross feeder is not just an installation issue, it can be a hidden root cause of multiple KPI problems.
If youβre dealing with:
β’ Unexplained KPI issues
β’ Coverage misalignment
β’ Suspected feeder problems
PoC available using your own network data.
