CPRI Interface Error Alarm
Can anyone explain what the CPRI Interface Error alarm indicates?
What are the common root causes and recommended troubleshooting steps?
Can you please share the alarm screenshot?
CPRI Interface Error means the fronthaul link between the baseband board (BBU) and the radio unit (RRU/RRH/AAU) has lost sync or is erroring — the optical serial link can’t establish or hold the CPRI frame. It usually resolves to one of: loss of signal (LOS), loss of frame/sync (LOF), CPRI line-rate mismatch, or Rx optical power out of range. Cells on the affected radio typically go down with it.
Root causes, physical-first (that’s the order to work them):
  1. Fibre/optical — dirty or damaged LC connector, bent/pinched fibre past its bend radius, loose or disconnected patch cord, too much attenuation (long run, extra splices, wrong attenuator), or Tx/Rx pair swapped. This is the single most common bucket.
  2. SFP module — faulty SFP either end, or wrong SFP: line rate that doesn’t support the configured CPRI option (e.g. 9.8G/10.1G/24.3G), mismatched wavelength, or single-mode vs multi-mode mismatch. Not fully seated counts here too.
  3. Rate / topology config mismatch — configured CPRI line rate or RRU port/topology (star vs chain/ring) doesn’t match the physical cabling.
  4. Radio side — RRU not powered / undervoltage / still rebooting, or RRU optical port HW fault. If the RRU is down, the CPRI error is a symptom, not the cause.
  5. BBU side — baseband board optical port fault, board reset, or RRU cabled to a different port than configured (slot/port mapping wrong).
Troubleshooting steps:
  1. Read the exact alarm sub-reason (which BBU slot/port, which RRU, and whether it’s LOS / LOF / rate mismatch / low Rx). That single field tells you which branch below.
  2. Confirm the RRU is powered and fully booted first — rule out “radio down” masquerading as a link error.
  3. Read Tx and Rx optical power (DDM) on both SFPs. Compare Rx against SFP sensitivity — low or absent Rx points straight at fibre/connector/attenuation.
  4. Reseat and clean both LC connectors, inspect the fibre for damage and bend radius, confirm Tx/Rx aren’t swapped, and swap in a known-good patch cord.
  5. Verify SFP type/rate matches the configured CPRI line rate on both ends, matching wavelength and mode; swap in a known-good SFP.
  6. Check configured CPRI rate and RRU port/topology mapping against the actual cabling; fix any mismatch.
  7. Isolate by swapping: move the RRU to a known-good BBU port, or a known-good RRU onto the same port — that localises it to BBU port vs SFP vs fibre vs RRU.
  8. If everything physical is clean and it still errors, it’s a HW fault: replace in the order SFP → RRU → baseband board, and escalate to vendor TAC with the optical readings and alarm detail attached.
Verification: alarm clears, RRU returns to available, the cells on that radio recover, and no CRC/bit-error counters increment on the fronthaul port. Watch 24h — an intermittent CPRI error that comes and goes is almost always a marginal SFP or a dirty/loose connector, not config.
Tell me the vendor (Ericsson / Huawei / Nokia / ZTE) and I’ll map this to the exact alarm name and the read commands for that BBU.
