What could be the best solution to cover a special campus area which consists of steel containers used for accomodiation?
LTE / 5G / WiFi ?
LTE / 5G / WiFi ?
Based on the factors mentioned above, the best solution to cover a special campus area which consists of steel containers used for accommodation is likely to be a combination of LTE and WiFi. LTE can be used to provide coverage for the entire area, while WiFi can be used to provide additional coverage and capacity in areas where the LTE signal is weak.
Possible solution:
This solution would provide good coverage and capacity for both indoor and outdoor areas. Users would be able to connect to the LTE network when they are outside or in areas where the WiFi signal is weak, and they would be able to connect to the WiFi network when they are inside or in areas where the LTE signal is strong.
Please note that this is just a general recommendation. The specific solution that is best for a particular campus area will depend on the specific factors involved.
